lcd 12864-3d
cschisler
Re: lcd 12864-3d
Post by cschisler »
sir what next? please advise.
Re: lcd 12864-3d
cschisler wrote: Sat Jul 27, 2019 5:10 am sir what next? please advise.
Thank you for your email address, my colleague will contact you.
befarfan
Re: lcd 12864-3d
Post by befarfan »
So I have a problem with my LCD screen, I was replacing the hotend of my printer and some of the screws were really tight because of filament residue, so I turned on the printer and set the nozzle to 155 deg. While I was unscrewing, I heard a little buzz, which suddenly stopped, however, I noticed that the LCD screen had turned off. I turned off the printer, and unplugged it, and kept taking off the screws. After replacing the hotend, I plugged it back and turned on the printer, the on/off switch lights up, but the LCD screen is still off as well that the fan for the control board doesn't work either. when I move the bed, the LCD and the fan work for as long that I move the bed. Will I have to replace the LCD screen or the control board?
Re: lcd 12864-3d
Hi, When you turn on the printer again, do the three lights on your motherboard light up?
like this:
cschisler
Re: lcd 12864-3d
Post by cschisler »
Yes all 3 red leds are lit solid.
Re: lcd 12864-3d
cschisler wrote: Tue Jul 30, 2019 3:31 pm Yes all 3 red leds are lit solid.
Hi, When you turn on the printer, the three lights on the motherboard are lit but the screen is not lit.
You can reconnect the screen cable to try.
If the screen is still not lit, you may need to replace the screen and screen cable.
befarfan
Re: lcd 12864-3d
Post by befarfan »
For my control board only one of the lights lits up, and it's not the one int the circle from the picture. So do I need to replace the control board?
Re: lcd 12864-3d
Hi, the picture is not displayed,
but if the printer is turned on normally,
three lights on the mainboard will light up.
cschisler
Re: lcd 12864-3d
Post by cschisler »
i've replaced the cable still no display. where can i purchase the lcd display board?
Re: lcd 12864-3d
Post by _kaktus_ »
befarfan wrote: Wed Jul 31, 2019 5:11 am ...
For my control board only one of the lights lits up, ...
Read the name from the PCB, and write which LED is lit. :!:
Maybe you just need to buy a fuse.
