GT2560 SPI pins for TMC2130
ADHdesigns
Re: GT2560 SPI pins for TMC2130
Hi I think I've come up with a better application of the mod. I've posted it on hackaday. I've had two of these drivers working on my machine for the last few months without any issues and I still can use the screen and SD card at the same time. https://hackaday.io/project/134374-addi ... s-to-my-i3
Looking through the board schematic, it looks like you may also be able to sacrifice the E1 stepper driver to gain 3 more available I/O pins, but I don't know enough about the ATMega chip to know for sure. The pins on the schematic are labeled in the current (1.1.8) Marlin firmware pins_GT2560_REV_A.h file as 47-49, for the DIR, EN, and STEP signals. The schematic doesn't show any components between the ATMega and the three pins on the stepper driver socket.
Hi all, I'm going creazy.
I've bought TMC2130 from Watterott and also from Cina (Fysetc 1.0) but I' get only "driver error"... I want to ask:
- Do I have to remove the jumpers on the motherboard (MS1, MS2, MS3) ?
- The following setup (open, close, close) is right? for Watterott and for Fysetc I mean...
[attachment=0]tmc2130_config.jpg[/attachment]
Thanks in advance, Lucio
- tmc2130_config.jpg (44.93 KiB) Viewed 21793 times
So to get Z working we can use Z max. Which means because auto bed leveling will need to keep using z min I just have to find one more pin. Have you had any luck doing that? Or should I look at a new board?
A small schema I've made so far for cabling
Your picture is for Fystec v1.0. Would have been more simple to buy the v1.1 version for SPIicelucio wrote: Fri May 18, 2018 3:21 am Hi all, I'm going creazy.
- The attached image (open, close, close) is right? for Watterott and for Fysetc I mean...
To change from 1.0 to 1.1 you need to open the soldered short cut and to add 2 super small solders
William wrote: Sat Jan 20, 2018 1:40 pm I suggest you use the TMC2100 because it is quiet and its pin definition is clear
Hello William,
can you explain what the following PINS are used for, as visible it the schema of SD Card connector by Nitocris from 30 Aug 2018 14:32:
PL7
PG1
PD7
Is it possible to use this pins as SS (Slave Select) for SPI communication to TMC2130, without giving up the SPI communication with SD Card or any other LCD 2004 functionality?
I do not have much experience with 3D printers yet, but after spending a lot of time on the internet I finally managed to run 4 x TMC2130 (x,y,z and e0) on a GT2560 Rev A+ board. The SD card and sensorless homing for the x and y axis work. I wired the SCK, SCO and SCI pins of the drivers to the SDcard connector as stated by Yellowtick in this thread but instead of plugin it on top, I soldered the cables to the bottom to be able to plug a connector cable to the front. To make sure the pins of the connector wouldn't move while soldering the cables, I plugged in a connector so that the pins could stay firmly in place.
Both Diag1 pins for the sensorless homing (x and y) need to be respectively plugged in the min x and min y pins on the mainboard but don't need to be explicitly declared in Marlin (the pins are just declared as normal endstops).
To be able to have enough pins I disabled the E1 pins as I only plan on using 1 extruder. This lets you repurpose the e1_dir, e1_step, and e1_enable pins.
In the pins_GT2560_REV_A.h file I commented out those lines:
hope it can help someone struggling with the same problem...
Code: Select all
//#define X_MAX_PIN 24
//#define Y_MAX_PIN 28
//#define E1_STEP_PIN 49
//#define E1_DIR_PIN 47
//#define E1_ENABLE_PIN 48
and added those:
// TMC2130 Setup
#define X_CS_PIN 24
#define Y_CS_PIN 28
#define Z_CS_PIN 47
#define E0_CS_PIN 49
After reading this post over and over, i still have problems to get my head around it (Arduino is not new to me).
I just want to keep it simple and replace only the X and Y with the TMC2130 V1.1 SPI driver. It's unclear the steps that i need to do.
Hardware:
- take out the original steppers = ok
- there are 3 jumpers on the 2560 (under de stepper sockets), do i have to change/take off one of those jumpers?
- insert the TMC2130 into the socket = ok
- the four wires coming from the TMC2130 , where exactly do i need to connect them? I can't find a schema or photo specifically for the Geeetech GT2560 V3
Software:
Which lines exactly in what files do i have to add/remove (i'm running Marlin 1.8 w BL Touch)?
I'm willing to pay $20 though PayPal for a nice, clean and simple manual that will make this install a breeze
I'm just to lazy to figur this one out i guess
Thx in advance!
Hardware:
Software:
Thx in advance!
Hi,I find this;https://www.youtube.com/watch?v=sPvTB3irCxQ&t=125s
