Hello
I have problem with cable connections marked "E"
I can't figure out where the connectors with 1 and 5 PINs should be put
Please someone can help me?
Thank you
A20 - connections
A20 - connections
- IMG_3194.JPG (241.24 KiB) Viewed 14762 times
Re: A20 - connections
Hi, You can check if your extruder motor is wired.
yes,
the extruded is wired with another connector
from the same cable there are :
connector for extruder
connector 5 PIN
connector 1 PIN
so, what I can do with 1 and 5 PIN ???
connector 5 PIN
connector 1 PIN
