Marks on side of benchy
evant8950
Post by evant8950 »
Hey everyone
I’m getting close on getting the benchy perfect. Would anyone have any idea on what is causing these marks on the side?
Re: Marks on side of benchy
:D Hi, Are you referring to the trace on your bottom?
You can try to adjust the hot bed,
Do not print too fast.
evant8950
Post by evant8950 »
The little marks on the side. It was hard to capture on camera. Thanks!
:D Hi, You can check the esteps on the screen,
Then see if your machine is loose, you can do it
Fastening treatment.
Jarda3d
Post by Jarda3d »
it is probably un-aligned joints
A10 Slic3r profile: here
