A20T Firmware with BL-Touch
Where can I get the firmware for my A20T with BL-Touch from? Best in .hex
Re: A20T Firmware with BL-Touch
Hi,T series firmware with 3dtouch is currently being tested, thank you for your feedback.
Hello Vert, thanks for the hint and the link, unfortunately I have a problem creating the .hex file. My Marlin IDE always throws an error message.
"exit status 1
Fehler beim Kompilieren für das Board Arduino Mega or Mega 2560."
My printer is an A20T with feeder upgrade to Bowden MK8 aluminum, 3D touch.
"exit status 1
I watched the video and followed the instructions as much as possible, unfortunately I also cannot compile with the "Visial Studio Code" software, which is still unknown.
error message:
Erstellen und Debuggen nicht möglich, da die aktive Datei keine C- oder C++-Quelldatei ist.
(Cannot build and debug because the active file is not a C or C ++ source file.)
error message:
did you load the extensions in visual studio code: auto marling build and platformIO ide
Creality Ender 3v2
Creality S10 Pro Marlin 2.0
Yes I have, unfortunately it just doesn't work for me.
I would be very grateful if someone could send me the .hex file
Standard A20T with upgrade to 3 x aluminum feeder (i need to invert the direktion) and 3D touch
can I create the .hex file in any other way, with visual studio code it just doesn't work
it finally worked, thanks for the effort and thanks for the work
Do you mind sharing the hex file or at least the configuration files used to get the firmware working?
Thanks.
Giuseppe Marullo
Thanks.
Giuseppe Marullo
