I just bought a geeetech A20m and a 3D wifi module. I tried to install it with easyprint 3d on my iphone 7+ as recommended in the furnished manual (see picture) but I never managed to get the page which allow to scan the QR code of my printer so the printer is always oofline. So I can't change the baud rate. So I get the same trouble as Yvon. Can anyone help us? Thanks in advance, Brigitte
Problem with 3d wifi module, easyprint3d and Geeetech A20m
- from the 3D wifi manual
- IMG_1049.jpg (331.9 KiB) Viewed 5806 times
Re: Problem with 3d wifi module, easyprint3d and Geeetech A20m
Hi, you can try to bind the serial number directly.
How can I do that? Thanks for your help.
Hi, you can refer to this:
Hello. Thanks for the manual which is more related to my version of easyprint 3D. The problem is still the same as I never get the message successfully bound. My machine is always unbind and offline. Thanks for your help.
Hi, you don't need to scan the code, you can click Manual and enter the serial number behind 3DWiFi to bind.
