Capacitive Leveling
Mrmaint
Capacitive Leveling
Post by Mrmaint »
I recently bought the capacitor leveler and installed. When the printer goes to check the height while setting up, it just climbs up to about 50mm total in 10 mm increments. The following is the data for the printer:
A30
Firmware: V1.38.58-1
Hardware: V3.4
Not sure how to correct the problem.
lion
Re: Capacitive Leveling
Post by lion »
Hi,you may choose the wrong mode i guess.
As the picture shows.
First, you need to select the type of automatic leveling module, 3D Touch or CAS.
If you choose “3D Touch”, click “Push-pin up/Push-pin down” and “Alarm Release” to test whether the 3D Touch function is normal before leveling.
And click the “Measure “icon, when the extruder head has moved to the center measure position, click “Offset Interval “to select the appropriate offset accuracy, and adjust the difference of height to set a available range between the bottom of 3D Touch pin and nozzle. And then click “Save”, the parameter of auto leveling is finished.In this case, the problem should be solved :D .
