Marlin 2.0.6
LoBoHEAT
Marlin 2.0.6
Post by LoBoHEAT »
Hi everybody,
I made the lastest Marlin for ours I3 Pro B, it´s with T8x2 rod, S Curve Acceleration activated and leveling mesh 4x4 points.
The repository it´s located at https://github.com/lachusmadeti
Any suggestion or problem don´t hesitate to say me for correct it.
Best regards.
Please, support my collaboration, buy me a Kofi https://ko-fi.com/lachusmadeti THANKS!!
Re: Marlin 2.0.6
Thank you for sharing! Excellent!:D
NCdotCom
Re: Marlin 2.0.6
Post by NCdotCom »
Hi! Thanks for sharing!
How to modify it for normal z axis rods?
Have a nice day!
LoBoHEAT
Re: Marlin 2.0.6
Post by LoBoHEAT »
NCdotCom wrote: Thu Oct 29, 2020 11:01 pm Hi! Thanks for sharing!
Have a nice day!
If you have the normal M8 rods are 2500 microsteps, for Tr8x8 are 400 microsteps.
Best regards
Darkmind
Re: Marlin 2.0.6
Post by Darkmind »
First of all, thank you so much for the firmware!! Great stuff :)
Just a quick question: I've uploaded the firmware by disabling the leveling (I don't have it yet), but homing always give -12 on X axis (Y and Z behave normally). X-stopper works perfectly, the printer detects it, but the coordinate is always -12 there. Not a big deal I guess, but seems a bit odd
Do you by any chance know what can be causing this? Anyone observed the same?
Parton4256
Re: Marlin 2.0.6
Post by Parton4256 »
Your article content is being very much interested, I am very impressed with your post. I hope to receive more great posts.
walgreenslistens
Donald255
Re: Marlin 2.0.6
Post by Donald255 »
I think you were directly about overflowing material. With brushing off ,1.5mm withdrawal and 0.6mm Z-jump primer tests hope to have tackled this issue, anyway it did noticabley lower surface quality which is additionally not ideal. Im going to try different things with longer than 2mm withdrawal lengths despite the fact that it is normally exhorted against for direct drive arrangements. Im speculating the withdrawal just isnt long enough for this Volcano/Titan clone.
GarageBand
JuAnGrAxXx
Re: Marlin 2.0.6
Post by JuAnGrAxXx »
Buena! Me llamo Juan y hace poco me compre una impresora i3 pro b. Viene completamente en blanco y he intentado instalarle marlin siguiendo tutotiales que he encontrado por internet y nada de nada. La pantalla sigue sin salir nada. Podria ayudarme un poco? Gracias de antemano
LoBoHEAT
Re: Marlin 2.0.6
Post by LoBoHEAT »
Darkmind wrote: Wed Jan 20, 2021 10:40 am First of all, thank you so much for the firmware!! Great stuff :)
It's normal, I defined at the firmware the offset of the X axis, if you meassure when home the printer the distance from the nozzle to the white line of starting print area it's 12mm.
With this when you mark to print at the center of the bed really print at center.
The levelling I defined it's manual leveling, the firmware isn't for the BL Touch/3DTouch.
Best regards.
LoBoHEAT
Re: Marlin 2.0.6
Post by LoBoHEAT »
JuAnGrAxXx wrote: Tue Feb 02, 2021 2:30 am Buena! Me llamo Juan y hace poco me compre una impresora i3 pro b. Viene completamente en blanco y he intentado instalarle marlin siguiendo tutotiales que he encontrado por internet y nada de nada. La pantalla sigue sin salir nada. Podria ayudarme un poco? Gracias de antemano
Buenas Juan,
la placa se enciende? puedes conectar con ella mediante Arduino IDE o pronterface? Revisa las conexiones de la placa a la pantalla, a ver si estuviesen cambiadas las del LCD por el lector de SD.
Un saludo
