Dear friend,
Could you please tell me whether the DIR Pin and STEP Pin on X Axis connected with the DIR Pin and STEP Pin on the slot of the board or not? I enclosed the pictures.
Waiting your reply. Best regards.
Azteeg
Re: Azteeg
- QQ图片20140714134805.jpg (22.96 KiB) Viewed 10677 times
Re: Azteeg
Yes they are.
How could they be anything else, as I said earlier the stepper controllers have the correct signals on.
Re: Azteeg
Dear friend,
We are finding solutions for your problems.
I will contact you as soon as we find out some useful information.
Sorry for the inconvenience and your understanding is highly appreciated.
Best regards.
Best regards.
Re: Azteeg
Dear friend,
Could you please change the DRV8825 on X slot?
You can put the DRV8825 which on Y slot to X slot to check whether the DRV8825 will get hot or not.
And you can change the stepper motor on x slot, to check whether it can work or not.
After you finish tested, please tell me the details.
Waiting your reply.
Best regards.
Waiting your reply.
Best regards.
Re: Azteeg
I cannot spend my life answering one question per day for an item that is "100%" tested. At this rate it will be several years before I have a working item.
Read this:
THE PCB IS FAULTY.
I will try to say it another way:
THERE IS A FAULT ON THE PCB.
Perhaps you don't understand those, try this:
NO WORKY, FAULTY ITEM, KNACKERED, GONE TO MEET IT'S MAKER, DEAD, DECEASED, EX, PAST TENSE DISCORPORATE,
Read this:
THE PCB IS FAULTY.
Re: Azteeg
Dear friend,
I really very sorry about that.
But I just want to find out the solutions for your problem.
I need to confirm whether the problem was caused by DRV8825 and stepper motor or not?
Could you please have a try? And then tell me the result, I will give you a satisfactory solution after that.
Waiting your reply.Best regards.
