RAMPS-FD
Lemon
Re: RAMPS-FD
Post by Lemon »
Dear friend,
Could you please uninstall the driver first, and then follow the steps:
1. Remove FD, remain DUE only, and please don't connect DUE with Computer.
2. Upload the driver via this link:
http://www.driverscape.com/download/arduino-due
3. Plug DUE again, let it installed automatically.
After finish tested, please tell me the results.
Waiting your reply. Best regards.
ps2gator.ebat
Re: RAMPS-FD
Post by ps2gator.ebat »
that link had a bunch of links that it tried to trick me into installing malware with huge "DOWLOAD NOW" buttons and fake "Download" buttons...I found the correct link eventually, but the page seems kind of strange.
Everything behaves the same with that driver as with the old
Lemon
Re: RAMPS-FD
Post by Lemon »
Dear friend,
Could you please download Driver Genius?
This is the link:
http://www.drivergenius.com/
Best regards.
ps2gator.ebat
Re: RAMPS-FD
that site is not in english.
the USB works fine when the FD power is off, and stops working when the power is on. This hardly seems like a driver issue.
Lemon
Re: RAMPS-FD
Post by Lemon »
Dear friend,
You can pull out jumper caps on VIN, and then use USB supply power.
Best regards.
ps2gator.ebat
Re: RAMPS-FD
with the vin jumper out, it acts the same as in my original post.
still not working.
Lemon
Re: RAMPS-FD
Post by Lemon »
Dear friend,
Could you please use USB to connect DUE and computer?
Please note that don't connect to FD and other peripheral device module.
Waiting your reply.
Best regards.
ps2gator.ebat
Re: RAMPS-FD
Yes. I have it connected to the usb.
what would you like me to do with it?
Lemon
Re: RAMPS-FD
Post by Lemon »
Dear friend,
Could you please tell me whether you can find com port or not when you connect DUE and Computer?
If not, maybe there has problem on 16u2. You can use usbtiny to upload bootloarder.
If you can find com port, the mcu probably has problem.
ps2gator.ebat
Re: RAMPS-FD
The Due communication works fine, unless the FD is connect with the power on AND the jumper as described.
