GPRS Shield does not work
Re: GPRS Shield does not work
so it's not sim cardconnector's problem.Maybe this modlue don't surpport your card,you can change another carrieroperator
I already wrote at the beginning, that I try also another simcard (Orange Tcom-O2-) and not one card does not work, the device is nonfunctional
AT+CPIN?
ERROR
It meens that Tthe SIM card is not inserted。so you‘d check that do you plug it up well,or is the cardconnector broken
ERROR
I measured all soldered connections simconector to sim900 and everything is soldered well, the picture shows the measured values certifying that the connector and soldered connections are ok, there remains the error in SIM900,
- sim900.jpg (271 KiB) Viewed 12680 times
All of Geeetech products have undergone first rigorous testing and second sampling inspection by professional inspectors.
It is almost impossible for us to ship you a defect driver. But it may be caused during transportation.As you know international transportation is hard to control, the package may not be treated friendly or handled improperly on its way to you. And the static electricity may cause short circuit,which is deadly for the chip.
I suggest you to contact the seller for further solution.
ok thank you for your willingness, vendor has already contacted and agreeing as to the items, one more time thank you very much
you are welcome,it's my pleasure
