Fanduct for Prusa i3 Pro and Pro B for better resolution
jgvonk
Post by jgvonk »
Best Geeetech users,
With the included STL files the I3 performance is a lot better.
Now I achieve a resolution of 0.06mm (nozzle 0.3mm)
Users of the Prusa I3 Pro should print both files and add them to the printer.
Prusa I3 Pro B users only need to print the Fan duct and add it to the printer.
Fan duct source: http://www.thingiverse.com/thing:729961
Thanks to thegman
Have Fun!
Geeetech Prusa Better Resolution with fanduct.zip
(148.79 KiB) Downloaded 1452 times
zhangxueyou
Re: Fanduct for Prusa i3 Pro and Pro B for better resolution
Post by zhangxueyou »
Thank you for your suggestion, jgvonk. But could you please tell how the install that part? I will be glad if you leave a picture. Thank you.
jgvonk
Post by jgvonk »
Here the pictures of the installed Fan duct. Fan duct falls below the extruder suspension for the Geeetech Prusa i3 Pro B and the original screws can be used.
Justinb81
Post by Justinb81 »
Is the extruder holder different as well? I see your extruder is more to the right.
Groetjes
jgvonk
Post by jgvonk »
It is the holder of the extruder Geeetech Prusa pro b. Is in the zip file
leonardo.galardi@gmail.com
Post by leonardo.galardi@gmail.com »
Does it improve also abs printing or only pla?
Justinb81
Post by Justinb81 »
Yes, I get it now. My metal plate between holder and extruder was flipped the other way placing my fan more to the left of the bracket. I've changed it now and tried the fan duct. I have a feeling it blowing to much on my heater block now. It takes for ever to reach its temperature. I'll try and rotate the block.
szeiger
Post by szeiger »
I have the same issue with the position of the duct, are we missing something? I'm printing the other stl you provided but it looks the same as what I already have. Please advise, and know the we appreciate your efforts.
szeiger
Post by szeiger »
This pictures goes with my last post.
szeiger
Post by szeiger »
I'll rotate the plate as mentioned above and give it a go.
