Printer dead? (Acrylic Geeetech I3 pro B)
3d Printer Noob
Re: Printer dead? (Acrylic Geeetech I3 pro B)
Post by 3d Printer Noob »
The red light on the switch is on; no LEDS on the psu illuminated.
3d Printer Noob
The red light on the switch is on, but no LEDs illuminated on the psu.
zhangxueyou
Post by zhangxueyou »
3d Printer Noob wrote:The red light on the switch is on, but no LEDs illuminated on the psu.
How do you connect the wire to PSU , is it like this:
3d Printer Noob
Yes. My psu looks a little different.
2015-04-11 02.23.09.jpg (515.43 KiB) Viewed 13106 times
3d Printer Noob
Just a reminder: it was working once while testing heat bed and heat head (several feet of ABS was successfully produced). When I had an actual object to print, it died when I set the heat head to start warm-up.
zhangxueyou
When you turn on the printer, is this light on? Is the fan in PSU working?
3d Printer Noob
No, the LED circled in the image is not illuminated, nor is the fan working.
elgroso
Post by elgroso »
Same issue for me :( :( ( power supply is dead prematurely !!)
It seems there is a REAL problem on power supply with Geeetech I3 pro B.
...Testing with an hold ATX power supply... and my pro B works fine !! :D
zhangxueyou
elgroso wrote:Hi,
I don't think so. Before we mass produced the PSU, we let the printer keep working with PSU for a week, and there is no any problem.
zhangxueyou
3d Printer Noob wrote:No, the LED circled in the image is not illuminated, nor is the fan working.
Can you take a picture of back side of the red switch?
