Printer is Built. Now What?
Zorce
Post by Zorce »
Acrylic i3 Printer
So I have the printer built but there are no instructions on how to calibrate it or what I need for my PC to run it?
Are there links on this subject?
zhangxueyou
Re: Printer is Built. Now What?
Post by zhangxueyou »
Hussain14
Post by Hussain14 »
Greetings,
I had built the printer I3 B, but I got problem with the Pc software.
should I use Repetier-host or another one
when I connect the printer with the Pc, and then opening the repitier-host. i got a problem for testing the printer.
when I chose connect, no option appaer to me as your description. the only option is ( default).
Please help because i have spent more time to run the printer.I thought that it is strightforward, but according to the manual that you sent to me is not.
waiting your reply,
my email is ( Ha2008am@hotmail.com)
Regards,
zhangxueyou
Hussain14 wrote:Greetings,
waiting your reply,
Regards,
Do you mean choosing the printer type? If so, only Repetier-Host costomerized by Geeetech has these options.
You can also download Repetier-Host at:
http://www.repetier.com/download-now/
Hussain14
Post by Hussain14 »
I already downloded the software, but the problen is that how to interface between the software and the printer.
when I press connect the following window appeared.I dont know if yoy can diagnose something from it.
after uploding the file for printing and the press print, it took me to this window
Then, when I go to the printer selection. i cant see the yype of my printer.so I chosed classic printer as in the below picture:
after that, wen I upload a file for printing and press print, no thing happen,instead it take me to another window.moreover i noticed that the extruder temperture not changing and heating at all. so, please advice what to do.
after pressing print, it take me to this window directly,So please your recommecndation is required to rectify this problem.
thanks for you
Hussain14
Post by Hussain14 »
hi,
Now, I have the following erroe,
what to do
zhangxueyou
Baud rate should be 250000.
If you want to heat up the extruder and hot bed, you should click the 2 icons highlighted in the picture:
If you want to print with the stl file, you should let the software slice first, click "Slice with slicer" as shown in the picture:
Hussain14
Post by Hussain14 »
hi,
I got now the Z and X motors rotate in the reverse action.I cant reverse the wiring.
So please send me the new firmware with reversing the direction of the rotation for the Z and X axis.( Y axis having now problem, when i press Y axis home,it go in the right direction)
my email is ( ha2008am@hotmail.com)
thanx,
Hussain14
Post by Hussain14 »
my printer is I3 B, with Sanguinolo Board
please send me also for the ramp1.4 if available
