Mightyboard Rev E wrong power connector
fruity
Post by fruity »
Hi, I have the original power supply for the Makerbot. It has a four pin connector. My Mightyboard has only two slots. On the underside there is what looks like a transistor or a diode.
If I replace the two pin female connector with a four pin female connector, will it break because of the diode? Or is it ok so I don't have to cut my beautiful male 4 pin connector.
Thank you. :geek:
zhangxueyou
Re: Mightyboard Rev E wrong power connector
Post by zhangxueyou »
It's ok. But please mind "+" must be connnected to "+" , and "-" to "-".
Don't care about transistor.
fruity
Post by fruity »
I just plugged my new Jameco power supply into the Mightyboard and immediately got smoking capacitors. I think I plugged everything in correctly, as the two +24V wires were going into the + side and the two - wires were going to the - side.
zhangxueyou
What is the output voltage of power supply? You plugged 4 wires to Mightyboard from Power supply?
fruity
Post by fruity »
The Mightyboard is receiving 24V from a new Makerbot Replicator 1 official power supply. I just checked it with the voltmeter again. the two positive legs are getting +24 over the two ground legs.
zhangxueyou
Which capacitor is smoking?
fruity
Post by fruity »
I just read the schematic for the Geeetech Mightyboard Rev E.
Are the correct inputs 12 V, not 24? I have TWO fried boards!!
I want a refund or I want to know what capacitors I can fix.
fruity
Post by fruity »
More than one was smoking. I tried plugging it in again after you said that to check, but I couldn't tell.
Mark
Post by Mark »
Can you post a pic here? And the way you connect it, I want to know which capacitor is smoking, tks!
fruity
Post by fruity »
Mark wrote:Can you post a pic here? And the way you connect it, I want to know which capacitor is smoking, tks!
Here's the picture. Can you help?
Screen Shot 2015-09-01 at 8.22.07 PM.png (790.26 KiB) Viewed 12932 times
