Printer Setup Problems
x306xcptnkirk
Re: Printer Setup Problems
yes it is v1.0.6 the extruder motors do not work either. none of the motors work on the printer before or after i changed the plugs.
zhangxueyou
You connect all the motor drivers in the opposite direction! That may even destroy the board.
x306xcptnkirk
They are connected as the instructions say....
- Screen Shot 2015-05-27 at 8.24.31 PM.png (431.79 KiB) Viewed 11252 times
x306xcptnkirk
So before I start this and try again this is the correct way to install the drivers???
- IMG_1137_Fotor.jpg (843.96 KiB) Viewed 11252 times
zhangxueyou
Yes, this is the correct direction. Because the driver you are using is DRV8825, and the driver you see on the internet is A4988.x306xcptnkirk wrote:So before I start this and try again this is the correct way to install the drivers???
x306xcptnkirk
Okay so I have them on and now they turn on and I can hear them buzz when I activate them. They do not move the motors still but they lock up the belts so they do not move.
zhangxueyou
The belt is locked up? Is the belt installed too tightly?
x306xcptnkirk
The belt is not installed too tightly. When the motors engage it allows no movement but does not move
zhangxueyou
Maybe the driver is dead because you plugged it in the wrong direction before. Can you move the extruder motor after heating?x306xcptnkirk wrote:The belt is not installed too tightly. When the motors engage it allows no movement but does not move
x306xcptnkirk
It makes sounds but does not turn the motor.
