Error Max Temp Bed
lalink
Re: Error Max Temp Bed
Post by lalink »
I'm back to the original problem again with the error being MAXTEMP BED. Is there anything else I can check regarding this problem? I can't seem to find a short circuit anywhere.
zhangxueyou
Post by zhangxueyou »
What are the resistance of hot bed thermistor and extruder thermistor? Are they both around 90k ohm?
lalink
Post by lalink »
The extruder thermistor measures a resistance of 98k ohms and the hot bed thermistor measures 97.3k ohms
Sherry
Post by Sherry »
Dear lalink
maybe you connect the wire of thermistor for extruder to hotbed.Normally,the hotbed temperature is 95 celsius degree.and the extuder temperature is 180 degree for PLA.please check whether the wire of hotbed is connected correctly.
lalink
Post by lalink »
I have already tried switching the two thermistors, the machine gives me the same error.
Sherry
Post by Sherry »
lalink wrote:Hello,
hi,lalink.it's because the wires connectd to the hot bed thermistor are short circuit.please do not get them together.
