Extruder fan
Sergio974
Extruder fan
Post by Sergio974 »
I have bought a Rostock G2s.
All works well, but extruder fan doesn't. A solution ?
Where can i find last firmware ?
(Sorry for my english)
Sergio974
Re: Extruder fan
Post by Sergio974 »
Sorry,
It is hotend fan who doesn't work.
My e-mail for firmware please: serge-aubert@laposte.net
Thank you for answer
Sergio974
Re: Extruder fan
Post by Sergio974 »
I made a mistake: it is hot hend fan who doesn't work, and it is connected on PWM.
Both extruders turn wrong way (filament goes out) what to do ?
my email for firmware please: serge-aubert@laposte.net
Thank you for your answer
Sergio
rxn123talon
Re: Extruder fan
Post by rxn123talon »
I am having the same issue with the hot end fan on a G2S. Was there a solution to this?
Sergio974
Re: Extruder fan
Post by Sergio974 »
rxn123talon wrote:I am having the same issue with the hot end fan on a G2S. Was there a solution to this?
No sorry. No answer for the moment.
Sherry
Re: Extruder fan
Post by Sherry »
hot end fan (pwn-fan) is controled by g-code.so it's running according to the code.
LENNS
Re: Extruder fan
Post by LENNS »
Re: Postby Eric » Tue Aug 04, 2015 11:14 am
my extruder fan does not turn ever - result overheating and melting of hotend. When does g-code turn this on?
Where in g-code to correct this?
rxn123talon
Re: Extruder fan
I use the settings in SLIC3R to turn the fan on.. It's in one of the tabs (I'm not in front of my computer with the program). I have it set to always turn the fan on and keep it at 100.
LENNS
Re: Extruder fan
Post by LENNS »
Thanks for tip but i tried that and fan never turns on. Is your fan two or three wire. I.e. yellow wire as well to fan?
Mark
Re: Extruder fan
Post by Mark »
The hotend fan only has two wires,as pic bellow. you can swap the fan with coldend fan to check if the fan was dad or not .
