Printing off
jbinion
Printing off
Post by jbinion »
Photo on 11-13-15 at 7.40 PM.jpg (58.24 KiB) Viewed 7344 times
Whenever I try to print after a couple of layers the extruder no longer lines up with the beginning of the print
Mark
Re: Printing off
Post by Mark »
Do you mean your Y or X aixs is skipping setps? maybe you can leave a youtobe link here to see what happens.
And you can refer to the link here to check the driver voltage:
http://www.geeetech.com/forum/viewtopic ... 13&t=17038
jbinion
Re: Printing off
Post by jbinion »
Yes, it is the x axis shifting. I have tried changing the driver voltage it doesn't change, it stays at 5.04.
jbinion
Re: Printing off
Post by jbinion »
I checked, all the drivers show the same voltage, but only the x is skipping
Mark
Re: Printing off
Post by Mark »
No, not the 5V one, you need to adjust the voltage through the potentiometer here, and increase it to about 0.9V.
A4988 voltage.jpg (217.64 KiB) Viewed 7306 times
jbinion
Re: Printing off
Post by jbinion »
HI,
Yes, I am aware of the correct place to make adjustments. It seems as though it is the bearings on the belt tensioner. When I took it apart one side fell completely apart. I figured if one better check the other, so both the x and y tensioner had the same problem. The bearings were broken on both of them. I will post pictures tonight when I get home again.
jb
