I3 Issues
bigcheese02
I3 Issues
Post by bigcheese02 »
Fired up my I3 last night to spin off a few parts, and much to my dismay something went wrong -
1. I plugged into my USB port on my laptop, but could not send anything to the printer via repetier-host. I got messages "10 commands waiting, 19 commands waiting" etc.
2. Manually moving the motors via the LCD panel - if I moved the Z-axis up, it would move fine - however, when I turn the knob to go back down, it said ENDSTOP HIT - Z.
I unhooked all of the end stops and tested again, still same issue, it would move up but then not go back down saying the endstop was hit :-(
I can't print at the moment, I did try and load a new firmware, which uploaded fine but it didn't make the problems above go away.
any ideas?
Mark
Re: I3 Issues
Post by Mark »
what's your printer type? I3 X or pro? the command waiting thing, I think it must be a wrong firmware or the baud rate is wrongly setted, you can reinstall the firmware to check it, and check the baud rate in printer settings and firmware both.
And the endstop hit, check it here:http://www.geeetech.com/forum/viewtopic ... 13&t=17037
bigcheese02
Re: I3 Issues
It's an I3 pro (8mm acrylic frame).
I noticed repetier-host had 9600 baud set, so I changed that to 250000 and it was communicating again.
will look at the other thread now and see if it applies. Thanks for the quick response.
bigcheese02
Re: I3 Issues
Do you have a calibration guide by chance?
The fix for the endstops worked great. I printed a calibration box and it's not 100% even.
thanks!
Mark
Re: I3 Issues
Post by Mark »
how it looks like? do you have a picture here? here's a link for you to improve your print quality, it's really good:
http://www.geeetech.com/forum/viewtopic ... 26&t=17183
bigcheese02
Re: I3 Issues
thanks for the link - I've done quite a bit of tweaking to it using that, but 2 things:
1. The roll of filament that came with the printer keeps breaking, not sure why it does that but as it's printing it will just snap and its a clean break, not like its rubbing anywhere, usually a good 10 inches from the top of the extruder.
break in filament
break in filament
2. I have yet to get a 100% complete print job and I'm not sure why. I took a pic this time, and I got a snippet of the repetier-host software output when it stopped.
stopped print job
stopped print job
3. Here's the snippet from Repetier-host.
repetier-host output
3d printer fail.PNG (25.82 KiB) Viewed 12106 times
Mark
Re: I3 Issues
Post by Mark »
uh...maybe it's quality is not that good, you can manually bend it see if will break easily.
as for question two, could you give me your stl files to print it with my printer see if it happens or not.
bigcheese02
Re: I3 Issues
Yes, it snaps fairly easily. :-S It's the roll that came with the printer when I bought it. I'll have to buy a better quality brand.
Attached are the STL and GCODE files I used. I used Slic3r to repair the STL before generating the GCODE.
controller_knob_6.4_mod2gcode.zip
gcode
(310.42 KiB) Downloaded 447 times
controller_knob_6.4_mod2.zip
stl
(20.95 KiB) Downloaded 457 times
Mark
Re: I3 Issues
Post by Mark »
I can print your stl with good result(no need to repaire), and I noticed your temperture for hotbed is 110, for hotend is 200? If you use PLA, then hotend is about 195-210, hotbed is about 60-70.
You can use my settings to print it, and I'll attach the gcode for you too. And your print quality seems not a cylinder, the bottom is melted ...
knob.zip
(361.06 KiB) Downloaded 480 times
