Hi Mark ...
i would like to know if want to print complicated object that needs "support filament" (PVA Filament) (objects with holes inside) can it done with the M201 ? moreover does the actual temperature the extruder can attempt (some reviews shows 270 oC) ?
Kindly advise
Regards
Support Filament for Prusa I3 M201
Re: Support Filament for Prusa I3 M201
the M201 has only one hotend so you'll need the same filament for both of them, if the filament is a different materail then it might not work. And the hotend, it will reach above 270 degrees but the PTFE tube inside the end of the throat should be kept under 245 degrees, it it works above that temperature too long then it might be melted or decrease it's lifetime.
