x axel missed 1mm
kristt
x axel missed 1mm
Post by kristt »
print a plus.jpg (404.93 KiB) Viewed 9090 times
please i need some help. i have a me creator and something is wrong.
when i try 2 make a plus it will make a fine perfect line on the y axel, then it make a perfect line from the midle and to the right.
then from the midle 2 the left on x axel it put the line 1mm under the midle im lost what 2 do????
Re: x axel missed 1mm
Check whether the belt inside the x-axis motor with loose and sliding is smooth or not, if this happens plz adjust.If everything is ok,try to lower the printing speed.
kristt
Post by kristt »
could it be the eeprom? . or something else, that do not operate.
I've tried to loosen and tighten , but can not see any difference .
what is your opinion
kristt wrote:could it be the eeprom? . or something else, that do not operate.
That's weired!Then you can see this,maybe it helps:
https://www.simplify3d.com/support/prin ... salignment
kristt
Post by kristt »
the problem is solved.
was missing a screw in the pulley
thanks William Kwok
kristt
Post by kristt »
pulley missing screw
missing screw.jpg (183.42 KiB) Viewed 9074 times
kristt wrote:the problem is solved.
thanks William Kwok
Good job,kristt!Very glad to see this.
