Problems with X Geetech i3 pro C
gpau
Post by gpau »
I have a problem with the X axis, when I press car home, the axis moves to the left without stopping the engine continues to run, the safety lock does not work.
I also have this problem I do not know how to solve
first layer height can't be greater than nozzle diameter
Thank you
Re: Problems with X Geetech i3 pro C
Did you have the X endstop correctly connected(X_min slot on the board)?
You can push down the X endstop after you "Auto Home" to check if it is working fine.
Or you can swap X endstop with the one on other axes to check if it was broken.
gpau
Post by gpau »
it seems strange that all three endstop are broken.
If the endstop works that setting should I do?
I have to change the firmware or do I have to touch anything else?
ggg666
Post by ggg666 »
gpau wrote: it seems strange that all three endstop are broken.
Probably not...You can check if you have endstops correctly connected(X-1,Y-3,Z-5),have a look at the following picture:
endstop wiring.jpg (135.73 KiB) Viewed 8707 times
