WILL RUMBA BOARD RUN THE M301
Aircraft Monkey
Post by Aircraft Monkey »
Will the M301 3-1 run using the RUMBA board with the original firmware provided by Geeetech that is used on the GTM32 PRO board?
Re: WILL RUMBA BOARD RUN THE M301
No,it can not support.
Aircraft Monkey
Thats ok, I found others that are running with RUMBA.
rynnn
Post by rynnn »
I've been having issues with getting my rostock 301 with the gtm32 pro board to work. I'm new to 3d printing but I know some things about computers so thought I could get this machine up an running. I've been having trouble with getting instructions on how to get the bootloader to flash on the board, what I should be using the st-link for (I can't get it to link to the board), the jumper instructions for this board, the gtm32 pro, and how to get it to work, when I click home it just crashes into the printer bed, and does this jackhammer thing. So finally I saw the hotend twitch and the screen went blank on my printer and now the board isn't connecting with the hyperterminal, it just says Jump app failed! From what I'm reading I need a new board now. I've never seen this printer running and really want to see it up an running, it's only 7 months old, I bought it from one of my teachers at school who couldn't get it working. How do I get a replacement board, and how long does it take to get, please advise, thanks.
You should contact the technical support.
technical@geeetech.com
