LEAD SCREW steps per mm nothing change
panosa
Post by panosa »
why when i change the steps per mm Z axis and upload the firmware (all done) nothing is changing .I have the same speed as it was before.i have enabled EEPROM also ..Is it anything else i need to do or my board has problem
Re: LEAD SCREW steps per mm nothing change
Maybe you should check if the change is worked via LCD panel to cat the Z-axis steps/mm.
