M201 firmware one new GT32 pro VB board
Hi, I got M201 to service because printer stops printing after minute or two, and I noticed new board GTM32 pro VB, but old firmware v1.0.0.3. I know new fimrware 1.0.0.5 resolves this issue and I tried to upload to new firmware. But I noticed that newest version for this new board is old 1.0.0.3 firmware !!!...tried to flash 1.0.05 for old GTM32 NON pro board and I bricked the board...I revert to correct M201 gtm32 PRO firmware and I revived board, like before but still has problem that printer stops printing sometimes after 1 minute sometimes after 3, sometimes after 5...no rules.
Can you send me new version 1.0.0.5 which correct this issue, but for the new GTM32 pro VB board?
Anyone has same issues?
best regards
best regards
Re: M201 firmware one new GT32 pro VB board
Maybe you need this(This firmware is for GTM32 VB) ?
download/file.php?id=2855
If your mainboard is GTM32 PRO,please download this one:download/file.php?id=2855
Bonjour
j'avais le même problème, j'ai donc téléchargé le firmware conseillé avec hyper terminal. Depuis j'ai des cases noirs sur l'imprimante et impossible de revenir sur l'ancienne version Message sur hyper terminal jump app fail !
Merci de me venir en aide !
You can refer to it uploading the old firmware:
viewtopic.php?f=20&t=60425
[quote=William post_id=81336 time=1509960069 user_id=51382]
Maybe you need this ?
[/quote]
This is not the m201 firmware (gtm32 Pro B)
We need the correct version for gtm32 pro b .. Thanks
[/quote]
[quote=William post_id=81440 time=1510797888 user_id=51382]
[/quote]
Bonjour,
J’ai pu récuperer gtm32_machine_m201.zip en désinstallant et réinstallant hyper terminal, mais j’ai toujours le problème récurant de coupure d’impression :
[img]http://www.neurozinzin.com/upload/2363_Cura_erreur.jpg[/img]
Pouvez vous me dire clairement si je peux régler le problème en installant GTM32_V1.0.5(GTM32)m201.zip (ou GTM32_V1.0.5.zip) avec le logiciel Flash Loader Demonstrator ?
Je rappelle que je possède une GEETECH Prusa I3 M201 avec une carte GTM32 pro vb
Merci !
[/quote]
Bonjour,
Merci !
This is a Hex file that you can convert to bin file and then uploading to the printer.
Bonjour,
Suivant les conseils de cette page car toujours des coupures récurrentes , j'ai entré le firmware GTM32_V1.0.5(GTM32)m201 comme conseillé, avec Flash Loader Demonstrateur.
Depuis l’écran de mon imprimante affiche des carrés noirs et ne fonctionne plus. J'ai essayé de revenir sur les anciens firmwares mais sans succès.
Pouvez vous me venir en aide
You should ensure your mainboard is GTM32 PRO VB and not a GTM32 VB
You should refer to this post and uploading correct firmware:
[quote=William post_id=81629 time=1512979565 user_id=51382]
[/quote]
Ma carte est bien une GTM32 pro Vb comme celle-ci : viewtopic.php?f=20&t=60425
et j'ai essayé de réinstaller download/file.php?id=2855 , mais je pense que comme j'ai installé (GTM32) m201.zip (GTM32_V1.0.5.hex) ça ne fonctionne pas.
.hex conseil après le premier post de cette page d'un possesseur d'une carte GTM32 pro Vb :
(98.94 KiB) Downloaded 22 times
[/quote]
post que vous avez d’ailleurs modifié , il ne proposait pas de choix et le texte était: vous avez peut être besoin de ça (GTM32) m201.zip sur fond blanc avec le lien: download/file.php?id=3639
En conclusion: mon imprimante ne fonctionne plus, j'ai apparemment besoin du fichier d'origine .hex.
Comment je fais pour l'obtenir ?
[/quote]
[/quote]
