very new to this. Been given a I3 A, full aluminium body. All put together and everything apart from the motor on the extruder seems to work. If I plug it into the Y axis motor port it works fine. This rules out the motor and wiring up to it. Pins on the control board look fine, not bent or creating a short. Could do with some suggestions.
Thanks.
I3 A older model extruder motor not working
Re: I3 A older model extruder motor not working
You can try to swap the A4988 of Y axis motor and extruder motor
