Problem no way
regisregis
Problem no way
After a problem psu, you send a new electric power. But LCD is down. Only lights up when i connect I3 to my laptop, LCD works. but no drivers finding.
And X Y Z don't move. Help !
- 1.jpg (476.39 KiB) Viewed 11761 times
- 2.jpg (309.06 KiB) Viewed 11761 times
- 3.jpg (283.47 KiB) Viewed 11761 times
- 4.jpg (358.34 KiB) Viewed 11761 times
- 5.jpg (200.94 KiB) Viewed 11761 times
Re: Problem no way
Have you re-attached the square power plug from the PSU to the board?
If you don't then the board will only power from USB and wont run the stepper motors.
regisregis
Re: Problem no way
after change LCD, not work...
https://drive.google.com/file/d/1Mukt4q ... sp=sharing
What's the problem? card? help me please, one month and don't work!!
regisregis
Re: Problem no way
Have you tried to check the voltage like the picture shows below?
- Z)4`_M49C$_K469[Z5WB(9E.jpg (172.07 KiB) Viewed 11677 times
Re: Problem no way
It should be 3.8V-5V.
regisregis
Re: Problem no way
I can't, no tool for this.
And now? i ask a new card?
Re: Problem no way
If it's not 3.8V-5V, then it might be the mainboard problem.
regisregis
Re: Problem no way
Hi, i bought a voltmeter and i tested the mainboard.
No measure, volt : 0.00
i bought your product by amazon...
Re: Problem no way
Maybe you can contact the sales to resend you a new one.
