New Firmware toolkits for E180/A30/D200
Admin
Post by Admin »
Hi guys!
Here is the new firmware toolkit for E180/A30/D200
You can upgrade the firmware or downgrade the firmware for your printer.
For users who wants your A30 work with 3dtouch/Bltouch:
First, you need to check if the "Extruder extension board" is standard.
You need to weld these 5 pins.
A30-3DTOUCH-extension board.png (756.93 KiB) Viewed 817778 times
Please download this version firmware and read the "Redme at first.txt"
A30_3Dtouch_V3.zip
(758.4 KiB) Downloaded 11004 times
For A30 and E180 users:
You need to update the UI for LCD after upload the firmware
A30 Refer to this post:
http://www.geeetech.com/forum/viewtopic ... 65&t=60740
E180:
http://www.geeetech.com/forum/viewtopic ... 64&t=60677
(D200 doesn't need to update the UI files)
If you need to downgrade the firmware to the lower version
You also need to downgrade the UI system of LCD!!
If you have not downgraded the UI system
The following are known bugs:
----Screen icon misplaced
----Screen show nothing
----LCD keeps restarting
*Please choose the correct UI files.
How to upload the firmware?(E180/D200/A30)
1, Download newest firmware tool from:
https://github.com/Geeetech3D/Smartto-Tool
2, Read the "README.md" file carefully and follow the instruction to upload firmware.
Update 2018.09.20:
We release a new firmware tool:
applications->
smartto_upgrador_1_2_forWin.zip
smartto_upgrador_1_2_forMac.app
PS: Please choose the mode "upgrade it from local"
Tips for the A30 upgrade to the firmware
E180 user can refer the tips of A30
D200 user needs to upgrade the ".363" firmware only.
1.Open the Smartto firmware upgrade toolkit
2.Choose the correct USB port and select the LCD firmware
3.Select the LCD firmware for A30
4.Upgrade from local
5.Restart the printer
6.Select the mainboard firmware for A30 then click upgrade from local
Re: Toolkits for E180/A30/D200
Post by _kaktus_ »
It is a pity that it does not support M201 ...
GeeetechUK
Post by GeeetechUK »
Is there a list off the upgrades?
Will the LCD be upgraded at the same time?
What is the serial number tool used for?
MichaelK
Post by MichaelK »
Firmware E180 Version: 1.25.30 available from EasyPrint3D.
Any release notes?
MichaelK
Post by MichaelK »
1.25.31 available.
Release notes?
nitro_sport2003
Re: Toolkits for A30
Post by nitro_sport2003 »
how long does the update process take how will i know it fished updating main board?
sasoromih.a@gmail.com
Post by sasoromih.a@gmail.com »
I keep receiving "Fail to execute script main". Solution anyone?
Gingko
Post by Gingko »
[quote=sasoromih.a@gmail.com post_id=84393 time=1527838366 user_id=65764]
[/quote]
Have you already inserted the SD Card?
ariel.ramraz@gmail.com
Post by ariel.ramraz@gmail.com »
Where do I download the firmware toolbox itself ?
Gingko
Post by Gingko »
ariel.ramraz@gmail.com wrote: Wed Jun 13, 2018 7:45 pm Hello,
Well, just those "toolkits" links above.
Locked
