How to downgrade/update the version of firmware---A30
Admin
Post by Admin »
Hi,guys!
Some people ask me how to downgrade the A30 firmware, and I'll share a link .You can download it.
Please note, if not necessary, please do not downgrade easily, new version fixed some problem
https://drive.google.com/open?id=1LIN6n ... p1J1aQbBDf
A30-V1.25.38 new version update
Toolkits(A30V1.25.38).rar
(15.11 MiB) Downloaded 2010 times
BikingViking
Re: How to downgrade the version of firmware---A30
Post by BikingViking »
Thanks for that, I downgraded and then re-upgraded to see if it would make a difference to my SD Card problems, but in both firmwares it says SD Card removed, but, during the update process, if I enable LCD updating, it writes the LCD firmware to the SD card, so the it is obviously able to communicate with the card and make changes to it through the USB connection even though I can no longer access it from the menu or write to it from any software while installed in the printer.
seawolf
Post by seawolf »
HI
can i use custom firmware for the A30 ?
is there and source code for the printer firmware
i have problem with the printer the Temperature Sensor for the HOTEND sum time work and sum time not working
and the Control Box it freeze ther is problem in the frimware there is bugs i thenk
i want the source code so i can fix the problem off the printer please
nitro_sport2003
Re: How to downgrade/update the version of firmware---A30
Post by nitro_sport2003 »
OK thanks was looking for this.
bini
Post by bini »
Hy,
I have a problem when I upgrade the firmware, and want to go at home, the motors for Z go up at the place to go Down...
Can you help me please.
Gingko
Post by Gingko »
bini wrote: Sun Jul 22, 2018 7:28 pm Hy,
It seems like Z-axis goes to the opposite direction.
You can use motor tool to change it:
viewtopic.php?f=17&t=60639&p=82054
BTW: New version of firmware has released, check this:
viewtopic.php?f=20&t=60676&p=82222
steveski21
Post by steveski21 »
Gingko
Is there a release notes or change log on the new firmware somewhere so we know what has been updated ?
Gingko
Post by Gingko »
steveski21 wrote: Tue Jul 24, 2018 6:56 pm Gingko
Link of Changelog:
https://github.com/Geeetech3D/Smartto-I ... angelog.md
You can find that in smartto readme page.
JackPonting
Post by JackPonting »
Many thanks for updating us about how to downgrade the version of firmware. Great to know about it.
Jack
http://www.qualitydissertation.co.uk/
Rascon54
Post by Rascon54 »
Thanks for the step by step tutorial. Works like a charm! The solution worked for me thanks to the community and the members for the solution.
firstcallonline
