I can't start printing!!
sss
Post by sss »
I assembled the geetech a10 printer. Then when I turned it on, I couldn't do as Step 4 of the Quick Start Guide's printing process.Image
When I turned it on, the LCD panel showed only this screen.Image Image
Is there a way to initialize the firmware or upgrade to version 1.1.9? What should I do? HELP ME!! (sorry for my bad eng. I am korean..)
schlulou
Re: I can't start printing!! HELP ME!!
Post by schlulou »
Just to make sure, you pushed the knob to bring up the menu and selected homing?
sss
Post by sss »
schlulou wrote: Sat Mar 16, 2019 9:49 pm Just to make sure, you pushed the knob to bring up the menu and selected homing?
NO! When the firmware was first starting, I didn't operate the knob. Homing was skipped, and I only saw x,y,z...and others..
Alxo
Post by Alxo »
Give the knob a gently push and you will see the menu, select prepare and then auto-home
sss
Post by sss »
Alxo wrote: Sun Mar 17, 2019 12:28 am Give the knob a gently push and you will see the menu, select prepare and then auto-home
Well, holding and turning the knob does not make the menu selection on the panel.
sss
Post by sss »
vert wrote: Sun Mar 17, 2019 12:29 am the instructions are not very good its telling you to click the knob go to the menu in to motion where the options it lists are.
sorry for you, I don't know how to update the firmware. I couldn't find the website that give me detailed instructions.
Alxo
Post by Alxo »
sss wrote: Sun Mar 17, 2019 12:16 pm
Hold? It is a push, just as a regular button
sss
Post by sss »
Alxo wrote: Mon Mar 18, 2019 1:53 am
Oh yeah, pressing the knob works. But I can't choose the menu even if I turn the knob.
Try to remove the LCD button.
Then you control the metal knob
sss
Post by sss »
William wrote: Mon Mar 18, 2019 3:02 pm Try to remove the LCD button.
It doesn't work .. In fact, I once dropped an LCD display on the floor. Can it cause trouble?
