Analog pins on GT2560 V3 (A20M printer)
andresdrb
Post by andresdrb »
I'm trying to connect a PT100 thermistor with amplifier. I managed to find a 5V and GND pins on the board, but don;t know where are the analog pins, or which numbers they would be.
Can anyone help?
Re: Analog pins on GT2560 V3 (A20M printer)
Post by _kaktus_ »
Hello.
The diagram available for this controller board does not correspond to the physical realization.
The board has a dedicated connector.
Here you have a description of the leads.
To check which pin corresponds to which µC lead, use a multimeter.
Unfortunately I don't have this controller board. :roll:
However, if you would like to present the results of your research here, it would be great. :D
