Easyprint and to Many material
Hi, I have a problem with my printer A30. First I used the current Cura version for slicing, but with large parts it didn't fit on the print bed although it should. Now I use easyprint 3d and the objects are centered. Now the problem is that the lines are printed perfectly, but when it has to be filled, the printer is either too slow, too much print material is required by the extruder or the lasers are flatter than they should be. Take a look at my pictures. What can that be? Do I have to adjust anything?
- 20190602_162434.jpg (249.51 KiB) Viewed 3141 times
- 20190602_162426.jpg (281.6 KiB) Viewed 3141 times
Re: Easyprint and to Many material
Hi, maybe you need to adjust the print speed and the distance between the nozzle and the hotbed.
Thanks William, but i have adjust The printing Speed, The Problem is The Same. use i Cura 4 slicer, it is perfect, Do I have another problem with the positioning on the printing bed
