Printrboard trace burn
techsupport
Re: Printrboard trace burn
Post by techsupport »
we know your problem,
but we have to send you a picture.
then you will understand how to solve the problem.
so pls send an email to our mailbox:Technical@geeetech.com.
or you can send me your mailbox.
and we will reply you and help you.
thanks.
Email: forum@geeetech.com
argus0209
Post by argus0209 »
I figured it out.
I have the make a jumper from the four pin 12v to the + on the hotend connector. Immediately the heatbed connector started working.
After more trouble shooting I have found the MOSFET on the hotend connector to be burnt out.
I'm am currently looking for a replacement.
I believe I should be able to repair both boards.
dmserve
Post by dmserve »
I am having the same type of problems as "argus0209"
I have 2 Printrboards neither one will heat the hot end.
One has the same burned trace as his Utube video shows, and the other does not, but neither works.
I Have checked wiring and software.
Research suggests a short in hotend, wiring, or board.
Have you had any problems like this before??
Other functions controlled by this board are working.
I like the board design and want to get it to work.
Thanks for your help
jack
Post by jack »
ok
we will deal it soon,thanks a lot
azlon
Post by azlon »
I also had a similar problem and fried 2 printrboard. Motors work fine, hotend also, but when I plug the heatbed it works for a few seconds and then both hotend and heatbed don't work anymore. So, then which is the best workaround? A 12V 10A relay? A potentiometer? Can you add the description of the workaround in the wiki? Thanks a lot.
Regars
jack
Post by jack »
Your power supply can be used,please potentiometer reference voltage to 1.0 v.and the com port disconnected suddenly?
