Need help
midiman310
Re: Need help
Post by midiman310 »
ScubaZan wrote:For the benefit of others that "may" make the same stupid mistake, I found the error with the temps.
The thermistor and power were reversed, Extruder1 to thermistor 2. Correcting that fixed the problem and there is no more issue.
Printer is running and giving good results. I've had a couple 3-4 hour prints without issue. The only problem I've run in to was for some reason my X axis limit changed by about 10mm at some point and I started printing off of the bed. Change probably happened on one of the several times I've switched back and forth between laptop and desktop for host. Easy enough fix.
I'm my opinion, this forum would be a lot more helpful to beginner printers like myself who will make simple errors if we were more freely able do request help from other users without moderation. Embarrassingly enough, my issues were all easy to fix newb mistakes that did not require "tech support." All it needed was, "Hey man, have you looked at this? Or tried this?"
Thanks Gents,
Zan
Awesome dude!
