MeCreator firmware needed please
nukes88
Re: MeCreator firmware needed please
Post by nukes88 »
followed it to a t and still getting this error. like i said i did the same changes and compiled the marlin firmware i got from them but o the one i got from geetech even the ramps one couldnt compile
this is the error
In file included from /dogm_lcd_implementation.h:38,
from ultralcd.cpp:36:
dogm_font_data_marlin.h:12: error: 'u8g_fntpgm_uint8_t' does not name a type
dogm_font_data_marlin.h:171: error: 'u8g_fntpgm_uint8_t' does not name a type
In file included from /dogm_lcd_implementation.h:40,
/ultralcd_st7920_u8glib_rrd.h: In function 'void ST7920_SWSPI_SND_8BIT(uint8_t)':
ultralcd_st7920_u8glib_rrd.h:28: error: 'DIOLCD_PINS_D4_RPORT' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:28: error: 'DIOLCD_PINS_D4_WPORT' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:28: error: 'DIOLCD_PINS_D4_PIN' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:29: error: 'DIOLCD_PINS_ENABLE_RPORT' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:29: error: 'DIOLCD_PINS_ENABLE_WPORT' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:29: error: 'DIOLCD_PINS_ENABLE_PIN' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:31: error: 'DIOLCD_PINS_D4_RPORT' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:31: error: 'DIOLCD_PINS_D4_WPORT' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:31: error: 'DIOLCD_PINS_D4_PIN' was not declared in this scope
/ultralcd_st7920_u8glib_rrd.h: At global scope:
ultralcd_st7920_u8glib_rrd.h:42: error: 'u8g_t' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:42: error: 'u8g' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:42: error: 'u8g_dev_t' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:42: error: 'dev' was not declared in this scope
ultralcd_st7920_u8glib_rrd.h:42: error: expected primary-expression before 'msg'
ultralcd_st7920_u8glib_rrd.h:42: error: expected primary-expression before 'void'
ultralcd_st7920_u8glib_rrd.h:42: error: initializer expression list treated as compound expression
ultralcd_st7920_u8glib_rrd.h:43: error: expected ',' or ';' before '{' token
zhangxueyou
Post by zhangxueyou »
Sorry, it's my carelessness. I've re-edited my last post in this topic, please check. You can refer to this page to upload the firmware:
http://www.geeetech.com/forum/viewtopic ... 20&t=16433
nukes88
Post by nukes88 »
Yea I did the fifth like in the beginning lol I've done it on a reprap before but never had the problem it's still the same error but I do have U8glb file in the libraries folder idk what else is wrong like I said the firmware I get the original marlin 1.0.2 works fine after I edit it compiles well
zhangxueyou
What version of Arduino are you using? Did you copy the correct "U8glib" folder?
nukes88
Post by nukes88 »
I have both 1.0.1 and 1.6.2 (I got board installed on this version turns out there was a way) and yes I unzip the U8glib folder which contains two more folders and a couple of other files to libraries in audrino. Like I said I can compile marlin 1.0.2 no problem jus the firmware I got emails have the problem
zhangxueyou
The firmware I sent you is correct. Can you give me some screen shots of how you address error.
nukes88
Post by nukes88 »
zhangxueyou
It has no problem with our computer. Please try to upload with other computer.
