Extruder Motor Not working...
Surfovod
Re: Extruder Motor Not working...
Post by Surfovod »
All items fulfilled, but to revive the stepper motor of the extruder and failed :(
Judging by the topics on this forum I the only one who has the same problem with the 2560 GT
I'll call the customer service.
Hock
Post by Hock »
Eric wrote:Dear friends
please try the following ways to solve the problem.
1.the extruder will move until the temperature was raise to 180 degrees for PLS,240 degrees ABS.Please check whether the extruder is heated up.
2.please swap the driver board with x-axis,if x-axis is working,the driver board is good.
3.please connnect the motor wire of the extruder to x-axis .if working,the stepper motor is good.
4.please re=download the firmware.Please refer to attachment.
If all above methods do not work,please contact the customer service.
firmware uploaded...
Also not working..............
Surfovod
Post by Surfovod »
Hock
if you solve this problem, tell us how to do
Hock
Post by Hock »
I also wish got someone tell me how to do now..... :lol:
Sherry
Post by Sherry »
Hock wrote:I also wish got someone tell me how to do now..... :lol:
If reloading the firmware doesn't work,please leave the order number or contact the customer service.
Hock
Post by Hock »
I buy from ebay,
transaction no is : 1391549858018
Surfovod
Post by Surfovod »
I've already written for service, but the response has not yet been
Admin
Post by Admin »
Hock wrote:Hi,
I have a Acrylic Geeetech I3 Pro B With GT250 control board & A4988 motor driver,
I set up every thing , & tested....X,Y Z motor work fine,but Extruder motor not working..
temperature of extruder ..check
spring tight ..check
motor driver.. check
plug extruder motor wire to x motor slot.. check
Exchang extruder motor wire with x motor wire.... check
motor driver voltage between 0.9-1V....check
I have try all this ,but still not work....
What should I do ??
Please Help......
Thanks.....
hi, my apology for delay in reponding.these are upgraded firmwares,it could make the extruder work now,please download it if necesarry.
GT_I3_pro_C.zip
(283.1 KiB) Downloaded 982 times
GT_I3_pro_B.zip
(283.1 KiB) Downloaded 968 times
Sherry
Post by Sherry »
Surfovod wrote:I've already written for service, but the response has not yet been
hi,the upgrade firmware will help you solve the problem.please reburn the firmware in the attachment.
Sherry
Post by Sherry »
GT_I3_pro_C.zip
(283.1 KiB) Downloaded 1056 times
GT_I3_pro_B.zip
(283.1 KiB) Downloaded 957 times
