firmware for Sangoinololu 1.3a
Re: firmware for Sangoinololu 1.3a
Sorry, I download the firmware again, you can check if it is what you want.
PI3B-Sanguino.rar
(229.88 KiB) Downloaded 439 times
MannyJayBustos
Post by MannyJayBustos »
Ok I will need to take the latest version of Marlin and go over each line of code and manually input the values from Marlin 1.0.0 and put them in to Marlin 1.0.2. That is all you needed to say.
Manny
oroszjrobert
Post by oroszjrobert »
Acrylic Geeetech I3 pro B 3D Printer kit
I need some help.
Assembled it correctly but the z axis does not stop after it pushes down the z axis minimum button ( I hope that is how you call that)
I have the same issue in the case of auto-home also same when I set the home setting manually. The motor keep stopping at the end point and is forcing itself but it will not go any further.
I hope you understand my issue.
Thanks in advance
