G29 autolevelling destruction G2S
Re: G29 autolevelling destruction G2S
hi guys i have something similar finally g29 succes changing parametters on marlin but when i test a print after g 29 and heating the spider goes dow and touches the bed causing an emergency stop the z eight defined all in the guide defined any idea guys????
Try to check your X/Y/Z axis direction, sometimes the wrong direction will cause the problem.
x y z are good wired cheking manually directions also good
moriartynz
I am not sure, but this looks like what I seem to be experiencing, namely that the G29 set of probing data seems to be creating a correction for points that are in error. My limited delve into the Geeetech Marlin firmware code shows me that the firmware uses a different method for calculating positioning after G29 is executed and there is autolevelling data available. My suspicion is that this calculation system for coordinates after auto-levelling is somehow completely wrong.
Regards
Regards
Try to check the probe of your spider.sometimes the probe couldn't go through the hole fluently and would get stuck by the hole, therefore the probe endstop will not trigggered. One of my customer reassembled his spider and probe, and drilled out the hole and make it freely for the probe to pass it and G29 works! Also he replaced the lock ring with a brass one to give the spring a much higher compression so it would work reliably.
moriartynz
Thanks Mark,
I have already replaced the lock ring with a brass one as the plastic one I was supplied with by Geeetech would not work (did not tighten). I have checked that the probe moves freely and also sprayed silicon oil through the hole for lubrication. I still have the G29 auto-levelling problem.
What position did you assembled the probe? it should be on the right of the spider, as the pic shows:
- QQ截图20150902134722.jpg (432.75 KiB) Viewed 15862 times
I was having this very same problem until I replaced my spider and hotends. In replacing them it cause me to really be careful about reassembly and I even took photos. The key I think was that
Let us all know how you go. OH Most important!!!!! When you start to set up your printer, the bench or table you set the machine on MUST BE LEVEL then start configuring your printer.
Cheers, Rick
- I took a couple of small drill bits and drilled out the probe hole enough to make it move freely,
- then I took the round sanding tool that Geeetech sent with the kit to clean out the top end of the probe holder to ensure that there was no sticking
- and finally replaced the lock ring with a brass fitting, which I believe everyone has had to do to get this to work.
Cheers, Rick
- Final assembly and direction it needs to be mounted
- IMG_2131.JPG (235.49 KiB) Viewed 15861 times
- Probe installed
- IMG_2123.JPG (195.17 KiB) Viewed 15861 times
- Hotends mounted
- IMG_2119.JPG (197.13 KiB) Viewed 15861 times
OK. I'll ask it. Why does the probe have to be mounted on the right? Yes, it has to be mounted opposite the fan, but why does it have to be mounted to the right as you look at it from the LCD?
moriartynz
HI Mark and Rick,
Thank you for your input. I did have the spider the wrong way round initially, but Eric (from Geeetech who sometimes posts on this forum) pointed out my error. I have subsequently reassembled the spider as shown in the attached image. The probe is on the right, the X to the left, Z at the back and Y on the right as you recommended Rick. I also widened the hole. I have not drilled it out as recommended by Mark and Rick as yet but with the silicon oil, the probe moves smoothly so I did not believe that friction was the issue.
The probe operates fine. I have a video showing my problem. https://www.youtube.com/watch?v=VMOQMlYJopk The video shows the device before I switched around my spider. The same problem happens after the spider was rotated so I have not updated the video.
Rick, was your device also trying to destroy itself mid-air like mine as shown in the video or was yours doing something different?
Regards
Regards
