bernbout
Re: Suggestion documentation - Prusa i3 Aluminium
Post by bernbout »
I don't understand what you mean about the extruder carriage. I never said anywhere that the documentation is wrong about which is the front/back.
All I said is that you show another printer with the XAxis rod clamps fixed on the inside and that this is the correct place for them. Also if you try to fix the LEFT clamps on the outside THEY DO NOT FIT because of the metal X Carriage fixture.
The manual shows them fixed on the outside and I said they should be on the INSIDE and showed the modification I did to enable the XCarriage stop to work.
TResell
Post by TResell »
帖子由 bernbout » 周二 2月 02, 2016 7:02 pm
sorry my bad, I misunderstand you! Now I see what you mean, but the prusa I3 design is not the same to the aluminium one, so the lock ring is inside.
bernbout
Post by bernbout »
TResell wrote:Thats a cool box bernbout. Is it possible to mount it on the powersupply without blocking the fan?
Yes it is. Check out the links below.
http://forums.reprap.org/file.php?406,file=70111
http://forums.reprap.org/file.php?406,file=70112
Download it here
http://www.thingiverse.com/thing:1303938
