How did you get OctoPi working with the M201? Every time I try to print, I get the status going from Operational to Cannot print immediately... I've never seen my M201 even start to print unless I am using Repetier Host to drive the printer
Layer shifting - help!
neilcoggins
Re: Layer shifting - help!
@stado65
Nothing special regarding Octopi. I tried and it worked. Just added a line in config.yaml for the buffer value (127 by default) but it worked without that line.
It always complains about wrong line numbers and the prints always stop a few seconds before the end. I also have to reset the GTM32 before each print then reconnect Octopi.
I think all this is due to communications pb with the firmware.
Finally Octopi cannot read/write the SD card...
neilcoggins
@stado65 I can't get beyond the "Operational" prompt in OctoPi, no matter what I do... If you have a set of configuration values I could have a copy of (and a set of what steps you use to get it to work), it'd be greatly appreciated!
Good news, though - I'm printing the last part for my MPCNC tonight! (Or at least, the last of the "generic" parts - I'll still need to print some tool adapters for the 52mm spindle and the E3Dv6 hotend that I will be using on it). Got everything apart from a 12V PSU now - going to use a 500W ATX supply for the unit (had to order another ceramic cartridge for the E3Dv6 though - originally bought it for my M201, and got a 24V version)
I'm also working on a set of replacement XZ-carriage parts for the M201 - going to base them off Enif's split X-ends (http://www.thingiverse.com/thing:514582) but modified to have mounting holes for the X endstop and also a second "vertical tube" to act as a Z-axis anti-backlash nut trap (basically, it'll contain 2 nuts with a compression spring between them to remove/reduce the backlash I see on all printed parts at the moment)... May as well make the M201 print as well as it possibly can...
Anyone know whether a (genuine) E3Dv6 will work without modification on the M201? Obviously I'll have to disable OFP and tell Repetier that I only have 1 extruder, etc - I'm more concerned about whether the thermistor will work OK...
Hi neilcoggins,
I am not at home now but I will have a look at my configuration for octopi and I tell you.
Attached is a screenshot of the Octopi html page (accessed from the internet) while printing parts of my future MPCNC
- M201.png (741.38 KiB) Viewed 12641 times
hi
i have the new m201 ver B with FW 1.0.5
i also have the same problem with the shifting on axis Y after one or two hours of printing
what to do please?
only on 30 speed its not shifting
thanks
yossi
what to do please?
thanks
yossi
printing 3D with M201 Geeetech
BTW
IN THE FW 1.0.5 THE acceleration IS 1000
its ok or reduce it to 500 ?
thanks
yossi
thanks
yossi
