My feedback on M201 printer after 3 weeks
elocm
Re: My feedback on M201 printer after 3 weeks
Post by elocm »
z-wobbling : I had similar issues. The minimal bending of the threaded road and maybe a collision to the upper fan of the extruder is the issue. Just to be clear the Z-Coupler must be assembled in the way it can compensate misalignment. Does mean the threaded rod mustn't touch the Motor- Z-axis. 5mm horizontal distance must be default.
Additionally you have to be careful with the fixture of the road. Also here you can create worst case 0.3mm misalignment (or compensate :D )
ball bearings : Please check my assembly suggestion for the Y-axis ball bearing. Some additional washer ad a distance part really helps. I ruined my first bearing also and was wondering of Y-axis wobbling and missalignment...
A4988 drivers : The X-axis worked fine for me. Same for the Y-axis until I killed my bearings on the other side. Took me days to find you where the extra enormous forces would come from. Please check also your X-bearings. Maybe same problem.
X axis endstop : Agree. Thex changed the end-stops and now everything is 3mm to far away. Have problems with x,y, and Z and helped myself by some modifications.
firmware : Same issues (all of them). Really crap and the bad thing there is no source code to fix it. This is really pain in the ass.
stado65
Post by stado65 »
Firmware 1.0.4 installed
No visible improvements : still the same communication issues (each line needs to be resent), no access to SD Card from Octoprint... :cry:
stado65
Post by stado65 »
@elocm
I almost completely solved the z-wobbling issue by replacing the metal couplers with printed ones (https://www.thingiverse.com/thing:1264447). The threaded rods are a bit bent but the main problem was the poor quality of the metal couplers (8mm and 5mm holes were misaligned).
I replaced all the ball bearings (X & Y axis) with new ones and it works perfectly now. Moreover, filling-up the LM8LUU with lithium grease dramatically reduced their noise.
I also ordered a second heater cartridge for the hot end as it has difficulties to reach and maintain the temperature needed for ABS (cannot go above 235~240°).
Regarding the firmware, I ordered a RAMPS board and I will try to use it on the M201 with dual-extruder capable firmware.
Finally, I am printing parts for building a delta printer (Kossel mini) and a MP CNC :-)
NicoFR
Post by NicoFR »
Same error on my side on big prints :(
As soon as the gcode exceeds 1M of line, I'm still getting the same error in loop:
Error:Line Number is not Last Line Number+1, Last Line : 1000001
Can you please give us feedback on this issue ?
panzo
Post by panzo »
which is the correct voltage for A4988 Z axis?
0.8v-1.2v is appropriate. And you can refer to this post.
