Hi Mark,
Could you give us an ETA for the M201 firmware update taking into account (some of) our requests regarding GCode support ?
M201 firmware - supported GCODE command list
Re: M201 firmware - supported GCODE command list
I just asked the engineer, might need you guys to wait for about two weeks, maybe the end of this month, hope you can understand.
OK, thanks for your quick answer.
the firmware has been updated to V1.0.5, just added some gcode commands, the other ones will be added later:
M92: Set axis_steps_per_unit
M110: Set Current Line Number M500
M502: Revert to the default "factory settings."
M300: Play beep sound
M304: Set PID parameters - Bed
Hi Mark,
Perfect !
Will try this ASAP
Perfect !
Will try this ASAP
The 1.0.5 firmware is a real improvement. The printer works flawlessly with Octopi now.
You did a great job, thx !
cerealkillers
Is there any chance the PID tuning commands will be implemented?
M301 - Set PID values
M303 - PID tuning
M500 - Save
M303 - PID tuning
M500 - Save
