Not printing after control board change
Admin
Re: Not printing after control board change
Post by Admin »
can i take a look at your control board, you need to use jumper cap if you use 8825.
you can check the building instructions, it was mentioned in wiring.
dandantas
Post by dandantas »
hey admin
i have all the three jumpers under each driver!
anycase i can not discovery which one is the multiply, could you show on this pic which is the MS1 Ms2 MS3?
Turn ON/OFF Subdivision
MS1 MS2 MS3
OFF OFF OFF full step
ON OFF OFF 1/2 step
OFF ON OFF 1/4 step
ON ON OFF 1/ 8 step
OFF OFF ON 1/16 step
ON OFF ON 1/32 step
OFF ON ON 1/32 step
ON ON ON 1/32 step
http://www.geeetech.com/wiki/images/f/f ... wiring.jpg
th building instrutions i have is this ones:
http://www.geeetech.com/Documents/Build ... 20M201.pdf
