Page 2 of 6
Re: Prusa I3 Pro B fails
Posted: Tue Jun 14, 2016 9:46 am
Bernd wrote:No, sorry it doesn´t works ! I have try everything... but i think the pressure for the filament is to low. When i push the filament with my hand down the fila comes out of the nozzle.
Hi,Bernd
I'm not sure if you've missed something...And have you tried to swap the driver module of the extruder motor with the driver module of the x or y axis motor?Cuz as you say,i guess there is insufficient driver ability to the extruder motor.Here is the driver module:
Posted: Tue Jun 14, 2016 12:59 pm
by Bernd
Yes , I have it Set to 1,15volts.
Posted: Tue Jun 14, 2016 2:43 pm
by Bernd
I swap one from the z axis with the one from the extruder Motor ! But is still the same problem.
Posted: Tue Jun 14, 2016 3:23 pm
Bernd wrote:I swap one from the z axis with the one from the extruder Motor ! But is still the same problem.
Another question,does the motor of your extruder work when you plug the input of it into the motor port of x or y axis on the motherboard?If it doesn't work,maybe the motor of your extruder is broken?
Posted: Tue Jun 14, 2016 3:43 pm
by Bernd
No, everything was great. All engines are running well.
I can see the wheel, it rotates when try to print. I use a flashlight and also in the right direction.
Posted: Tue Jun 14, 2016 4:04 pm
Bernd wrote:No, everything was great. All engines are running well.
Alright,then has the voltage between them been measured already?It is right?
If that is also correct,the reason i can think can only be the gap between Philip screw and gear,you can adjust the gap little by little until it is appropriate. :o
Posted: Tue Jun 14, 2016 4:18 pm
by Bernd
Yes the Voltage is right.
I can not unfortunately adapt because I can not get close to this Philip screw or set at all.
Posted: Tue Jun 14, 2016 5:38 pm
Bernd wrote:Yes the Voltage is right.
The attachment 13444375_10205639647984790_932889321_n.jpg is no longer available
Hi,Bernd
I just looked the extruder as yours,and i tried to plug the filament into it,i found the gap was enough tight.So i think the pressure is sufficient to the filament to flow.
And you had better check if the extruder temperature has reached the lowest working temperature for your filament,if that is right,pleaser verify your nozzle is not clogged again.
Finally,if those are right,you can have a try to increase a little dirver voltage to 1.3~1.5V by adjusting the potentiometer screw below:
Good Luck!
Posted: Tue Jun 14, 2016 10:31 pm
by Bernd
i did this and put on several volts 1,35 1,45 and 1.5v ... and now only buzzing the engine but nothing else happens. That just can not be right
Posted: Wed Jun 15, 2016 9:38 am
Bernd wrote:i did this and put on several volts 1,35 1,45 and 1.5v ... and now only buzzing the engine but nothing else happens. That just can not be right
Its so weird...Sorry to tell you that you had better check them above all carefully again,maybe you missed something indeed.Cuz there's no other problem about this.
