Page 2 of 2
Re: Fans issue geeetech i3x printer
Posted: Wed Jul 13, 2016 9:47 am
shadowcaster wrote:Hi. I ask to seller and he told me to check jp2. If not connected, to use a cap...
I use a 12v input...
I am confused.
Don't worry.You can have a try.The fans will get the power supply from the PSU directly after you do that.
Posted: Wed Jul 13, 2016 11:53 pm
by shadowcaster
Hi. I have 12 v on that pin. Now what can i do?
Posted: Thu Jul 14, 2016 6:40 am
by shadowcaster
Hi. I tried it and my fans come to life...also pwm fan works properly. But why? What is the difference between cap on jp2 or not? Only powers on fans?
Regards.
Posted: Thu Jul 14, 2016 8:57 am
shadowcaster wrote:Hi. I tried it and my fans come to life...also pwm fan works properly. But why? What is the difference between cap on jp2 or not? Only powers on fans?
Regards.
With the cap,the fans will get the power supply from the PSU directly(Your DC output is 12V,and your fan's operating voltage is 12V too,so it's OK).
And without it,the fans will get the power from a regulator chip.
Posted: Thu Jul 14, 2016 4:36 pm
by shadowcaster
So the chip doesn't work properly? But on the voltage regulator i have 12V...
Posted: Thu Jul 14, 2016 5:01 pm
shadowcaster wrote:So the chip doesn't work properly? But on the voltage regulator i have 12V...
It is possible some other around the chip doesn't work properly...
Posted: Thu Jul 14, 2016 5:33 pm
by shadowcaster
Hi. Thanks for reply. Can you provide me the circuit schematic or pcb so i can i check the issue? Regards.
Posted: Thu Jul 14, 2016 5:45 pm
shadowcaster wrote:Hi. Thanks for reply. Can you provide me the circuit schematic or pcb so i can i check the issue? Regards.
Sure,here it is:
Regards
Posted: Thu Jul 14, 2016 6:28 pm
by shadowcaster
Thanks a lot!
Posted: Fri Jul 15, 2016 4:44 am
by shadowcaster
Hi. Thanks a lot. Can you provider me the pcb's section relatively power fan route trought JP2? Regards.
