pin layout for gt2560 board
lensfort
Re: pin layout for gt2560 board
Post by lensfort »
You've likely found your solution by now. But I had a similar issue and needed to find the pin layout for this board. It's here
http://reprap.org/wiki/Geeetech_GT2560
And in pins.h it's listed under "Ultimaker" as you can see from the:
Code: Select all
Introduction
The Geeetech GT2560 is an Ultimaker derived board. It is a single-board design, which has an integrated ATMega2560 16Mhz processor.
Can confirm, I was looking for the Heated Bed Pin and it's indeed on PIN 4 and the Ultimaker profile is the only one there with that.
