i have the same problem on my M201.
The fuse IE10A has 24V, the fuse IE15A is dead.
Where can i get them? Can you send me?
Burned MotherBoard
Re: Burned MotherBoard
Hi,Benni94 wrote:Hi,
The voltage we talked should be between every side of the fuse and GND,which means we have four 24V in total on the two fuses.
You can figure out which fuse is dead then contact your seller to talk about it.
I figuered out, that the 24V fuse is dead, but i already found out which fuse to buy. Maybe you should write somewhere which fuses are used in the board, so other can find easily the right one
