X Axis no torque in one direction
cesar77muse
RepRap motor knocking when sending G2 code
Hello I have a geeetech g2s pro and when i am calibrating the axis everithing goes good until i reached the G2 code which calibrates de Y axis motor, it sounds like something is cracking and the belt doesnt move properly
here is the link to make you understanding me better
https://www.youtube.com/watch?v=K83q3X48qQU
thank you so much for your time .
Re: X Axis no torque in one direction
Did you find where the noise come from?
I saw your X motor didn't home at the end of your video,so i wanna know what commend you gave it finally?
cesar77muse
Hello, i gave th G2 command which controlls the calibration on the Y axis, this is the script:
G0
X0
Y63
Z2
Then i home the printer and the noise comes up, this only happen when this position.
And the Motors reach the home position actually,sorry i stopped the video early .
G0
X0
Y63
Z2
So you mean all the movements are normal except that?
cesar77muse
I got a new A4988 board and inserted it. I'm now receiving correct voltage across the potentiometer. Yay!
However, now the x axis doesn't move at all.
I've reuploaded the firmware, but still nothing.
Do I need to do anything else?
According to what you said before,it is the bad driver indeed.I did. Any other driver board in the x axis socket works fine. The x axis board in any other socket, does not.
It is not possible you received another bad one...Did you plug it in a right direction?
You still can swap the new one with other axes' to have a try.
Ok, I've actually measured the voltage on the cable, swapped boards, swapped cables, and the new board isn't supplying voltage to the motor.
Sounds like the replacement board is dead, too. Or am I missing something?
I got a new board, and it works! I was just unlucky enough that the replacement board was also faulty. Thanks for your help.
Your new board means the driver board A4988?I got a new board, and it works! I was just unlucky enough that the replacement board was also faulty. Thanks for your help.
