M201 Crushing Z endstop with lead screws
Re: M201 Crushing Z endstop with lead screws
I'll give that a try.
I think you are right with the board being bad. I redid to solder and after I hooked everything up, it's acting as if the limit switch is always triggered. There is no short between the leads.
What are my options for getting a replacement? Is changing to the new board possible? (I see that it would probably require a different lcd board and a different mounting bracket for the primary extruder)
Edit: Redid the solder again and it's back to what it was doing before.
Could I get a response?
Is this potentially a problem with how the firmware was programmed or is it a most likely a hardware failure of the main board?
Either way, what are my options for getting this fixed?
edit 10 May: Replacement parts on the way
